BitWrangler wrote on 2024-03-14, 04:02:
My most shitty PC Chips motherboard I have is an M741LMRT .. it has defied me... I've got about 7 or 8 other PC Chips that are fine for what they are, even a couple that impress me. This one though, has all the frequently complained of faults. Thin board, bad soldering, general jank.
The shitty to working ratio of PC Chips though is HIGHER that that of Asus boards here, with a dead A7V333 A7V133 P2B P3B among those number. So Asus actually gets first place for shitty boards, because 30% of their boards I have don't work right.
I've had about the same experience. I got lucky and made some strong retro-pc part contacts over the years, from recycling to refurbishing centers as well as other collectors, and i've had loads of boards from various manufacturers pass trough my hands. So far Asus has been the most dissapointing brand. Their low-end boards are pure e-waste, with a few exceptions. Their mid-end boards are 50/50. I've had no issues with P2B boards, I've had some that came covered in mud, with rusty I/O, witch, after a good wash, inspection and replacement of destroyed I/O (PS/2, serial, etc) posted just fine. The P3B on the other hand is not as reliable, but it is nicer to use when it works.
I did own asus boards I liked a lot - the Asus P6T Deluxe is a good board, I've had 3 of these over the years, used for different builds (server, gaming PC, work PC) and they all worked like champs. I was also pretty happy with an Asus P9X79 DELUXE. In fact I still have the whole PC. 3930k, still doing 4.2GHz on that board, 16GB of 2133MHz DDR3 ram, and a GTX 580. That build lasted me since 2012 all the way up to 2020, first used as a workstation, and later as my primary PC. It's had 7970 GHz edition, R9 280x, GTX 970, GTX 1070, and even a GTX 1080ti in there, and it was used, at least for the latter part of it's life.
Gigabyte comes second with 20% Though on a lot fewer boards and I'm angrier at them because some were bought new enough that warranty replacement should have happened but they were all deny deny deny.
I don't get nearly as many old Gigabyte boards, but with the exception of the Gigabyte GA-7VRXP (2 boards, same symptoms) witch I have stability issues with, a few GA-7VAXP KT400 boards (2 out of 3 dead boards, shorts, bad VRM - worked when put in storage, let out magic smoke when I retested them months later) and the dog slow GA-8IPE1000, I find gigabyte to be fairly reliable. In fact some of my more recent modern builds have had Gigabyte boars and I'm very happy with them. Right now my main PC is running an B550M Aorus Elite. Before that I had a B450 Aorus M. Before that I used an MSI Z77-G45 that was quite OK, and before that I had a Gigabyte X79-UD7 witch had a wierd issue where it would fail to post and reset CMOS settings every 3-7 days or so. I still have one of these, another board I sourced second hand, it has the same issue.
