Reply 560 of 717, by PC@LIVE
- Oldbie
I put my paws back on the MB 486, SMT Terminator PCI/ISA, it is the only 486 card with PCI slot that I have, I have never tried it, because it has some work to do, for now I have limited myself to looking at the microscope, in the back there are several very corroded tracks, and some that seem interrupted, from the top, there is some very corroded traces near the battery holder, but above all there is a lot of oxide in one of the ALI chips (chipset), and also in the sockets of the cache chips, in addition to the 72 pin RAM sockets, beyond this there is a lot of microdirt.
Some welds should probably be renewed, I don't know if the previous owner had tried to clean the board, and this would explain both the oxide and the very dark welds, I would think that he did not dry the board, and left it for a long time in a humid place.
For the initial tests, I will use a CPU that does not need a heatsink, like a 486 SX or DX, if after some work, I get the resuscitation, I will switch to the 486 DX4, or possibly to the 5X86 133-P75 from AMD, 1 MB S3 PCI video card, ISA sound card, a couple of RAM probably 8 or 16 MB each, memory card with Windows 95, capacity of at least 512 MB, but first I have to do the usual DOS bench with the card I usually use.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
