Well, this was a cool find! I saw these in a lot with some other parts recently. At first I actually only noticed the Kingston SX Now SX/20GDM upgrade card (with AMD 386SXL 20Mhz), but after seeing the other side of it I realized that it was intended for a less common PGA-68 286 socket. Then I realized that one of the motherboards in the lot was from an IBM PC AT 5170 (Type 3 with 8Mhz 286) and it actually uses this same socket, whereas most 286 processors I have come across are PLCC, LCC or PQFP.
The attachment 20241205_211121 (Custom).jpg is no longer available
Sure enough, it slots right into this board once the CPU is removed.
The attachment 20241205_211143 (Custom).jpg is no longer available
The attachment 20241205_211222 (Custom).jpg is no longer available
The pins on the SX Now were mostly okay but one was bent pretty severely. I was super gentle while trying to straighten it and it still broke off, but I'm happy to say that it is one of the few NC (not connected) pins in the PGA-68 socket, so this has no impact on it's functionality. 😌
The attachment 20241205_211259 (Custom).jpg is no longer available
Just in case it ever becomes important, I attached the pin with a tiny piece of clear tape to the bottom of the SX Now so it doesn't get lost (yes, I have moved it since taking the picture... it was a bit too close to some vias 😮 ). If I ever come across some through-hole pins that match the others, I would prefer to just solder in a new one, though I don't know if it's as easy as it looks to replace it.
I'm not sure why the board had a CPU while the matching upgrade was in the same lot, but it is awesome to find such an uncommon upgrade card. I can't find a single picture of this particular one online.
