Reply 260 of 315, by RaVeN-05
- Oldbie
done, behaves same way(
menu have hall of mirrors , background
Pah!
https://patreon.com/Rready
Once again:
https://1drv.ms/u/s!As-dKk-N73dSmDfT5-syDoFTPIAB?e=fzpO4r
MD5: 85957e3658ac38903256dd9c247f775d
Delete all previous redline.dll and verite.dll and R1dline.dll and V1rite.dll files in the Formula 1 foplder.
Copy the new Redline and verite dll and the Formula 1 microcode into the Formula 1 folder. The Rendition driver redline.dll and verite.dll files should be in the system32 folder.
This version forcibly loads the microcode from the F1 redline drivers. My investigation into DOS/Speedy3D support now indicates the microcode decides what low level signals (via interrupt flags) get sent back to the apps for Speedy3D and RRedline 2.0 for Formula 1. RReady deals with a lot of different games as a special cases so the microcode probably doesn't affect it. These signals can cause the Verite chip to stall.
Logging is enabled, sorry.
BTW @Chucky, you were absolutely right, microcode plays an outsized role in this thing. It's going to complicate Speedy3D support for RReady.
microcode , especially in dos a spd3d.uc its like glide2x.ovl for 3dfx i think? the right microcode can show graphics glitchless?
there is somewhere i saw full collection of those *.uc files.
And i still believe that with right UC microcode games like Descent II , Scorched Planet can be played without magenta/pink tint on v2000.
And other dos games.
As for Formula 1, now it closes instantly after black little window blink once, once i ran, 1 frame.
10:51:13.880 Redline loaded system\redline.DLL library10:51:13.880 Redline.dll local verite path G:\PROGRAM FILES\FORMULA13\Verite.dll10:51:13.880 Redline.dll successfully load system\Verite.dll library10:51:13.880 No IndirectSRC10:51:13.880 VL_OpenVerite_10:51:13.880 V_EnumVeriteBoards10:51:13.880 Callng base function10:51:13.880 V_CreateVerite10:51:13.880 G:\PROGRAM FILES\FORMULA13\WINSPD3D.UC10:51:13.880 DllMain Process Detach
2024/03/10 10:51:13.880 Started loggingForced refresh rate is 60(local) Redline.DLL G:\PROGRAM FILES\FORMULA13\redline.dllSuccessfully loaded library (local) Redline.DLLSuccessfully loaded all library functions (Verite.DLL)Loaded system\Verite.dll library
RaVeN-05 wrote on 2024-03-12, 09:12:microcode , especially in dos a spd3d.uc its like glide2x.ovl for 3dfx i think? the right microcode can show graphics glitchless […]
And other dos games.As for Formula 1, now it closes instantly after black little window blink once, once i ran, 1 frame.
You're right. The microcode can control what signals are sent back to the CPU. Not just that, it can modify VRAM, registers perform compute ops and has a full set of branching instructions. Among it's best features are locking up, if the uc writer's careless.
There're two different levels of microcode V1000 and V2000. A V2000 chip can run V1000 microcode if it's switched over to "V1000 compatibility" mode. Don't know how to do that yet.
Some V1000 instructions used for updating state are illegal on the V2000. I *think* the V2000 automatically updates these registers and doesn't need manual writes during rendering (some ops lock certain actions for a number of cycles. Not all instructions, just some).
I don't get why RRedline 2.0 chcoked on RRedline 1.0 uc. The drivers should be able to switch to V1000 mode somehow. Might be the wrapper.
And now this:
https://1drv.ms/u/s!As-dKk-N73dSmDiE-Mg_0uDd0aDl?e=QBq7EW
MD5: 4837db47e682e08f04322d34c62353c7
The docs for:
v_error V_CreateVerite(v_u32 board, HWND hwnd, v_handle *pvhandle,char *microcodefile)
board Number of Vérité board to usehwnd Window handle of the applicationpvhandle Pointer to Vérité handle to be initializedmicrocodefile Name of Vérité microcode file to load
say microcodefile isn't a path, but a name. I was passing a path. So this time around I'm passing the just the filename and not the path.
It's possible it'll look for the microcode in system32. If this doesn't work, I'll get you a different build using a different microcode file (with a different name) , which you'll have to bung in the system32 folder, but not in this build.
video, going to blck screen with some artifact pixels
One more, different microcode file (V10003D.UC). I think I got the WInspd3d.uc. I think this is what's needed:
https://1drv.ms/u/s!As-dKk-N73dSmDkAfnTtjTkc1SP6?e=SqgZ3d
MD5: 0de26691589cc516ef4c2f2b7fe9f028
I think this is the UC file used by the V1000 for 3D. There also V10002D and V1000GL (OpenGL perhaps?).
[EDIT] I just hope it's not a Direct3D file.
Progress! First 3d demo scene appeared glitchy and hangs actually crashes to desktop after i pressed esc
logs on fex also as videos
Woohoo!
It's painful watching slow mo videos. It must be worse for you actualy trying this stuff out.
[EDIT] Well done, all your testing has paid off or will soon. But I must admit feeling stupid. Chucky was going on about the firmware and I should've really tried this before. This is much simpler, if it works, than all the other stuff I tried.[/EDIT[
https://1drv.ms/u/s!As-dKk-N73dSmDtff_UC6F6_BKZg?e=96ga0K
MD5: 9b56a9aa10b410ce7f976104a3e7be21
This uses the V20003D.UC file. If it doesn't find it, just copy it from system32 and pasted it into the Formula 1 folder. I think it just needed the UC file to be specified.
Logging has been disabled, mostly. It can be sped up in other ways. There're a lot of unnecessary checks in there.
13:48:36.960 Redline loaded system\redline.DLL library13:48:37.010 Redline.dll local verite path G:\PROGRAM FILES\FORMULA13\Verite.dll13:48:37.010 Redline.dll successfully load system\Verite.dll library13:48:37.010 No IndirectSRC13:48:37.010 V20003D.UC
regress, no 3d scene
https://fex.net/s/5tnxdre
RaVeN-05 wrote on 2024-03-12, 12:07:regress, no 3d scene https://fex.net/s/5tnxdre […]
13:48:36.960 Redline loaded system\redline.DLL library13:48:37.010 Redline.dll local verite path G:\PROGRAM FILES\FORMULA13\Verite.dll13:48:37.010 Redline.dll successfully load system\Verite.dll library13:48:37.010 No IndirectSRC13:48:37.010 V20003D.UCregress, no 3d scene
Try copying V20003D.UC from system32 to the formula 1 folder.
And here's a logging free V1000 version:
https://1drv.ms/u/s!As-dKk-N73dSmDxZ3hXzsS92Xnt8?e=cUoeaE
MD5: 18392c7b5f285bcba3801f4992414554
If you can't find V20003D.UC try this file:
https://1drv.ms/u/s!As-dKk-N73dSmD1YJbhfEedj0I-m?e=T48vS2
MD5: 14d244c2f6e1ac8f08050e9800b9b227
Copy it into the F1 folder.
i found and placed v20003d.uc does nothing. same results
with v1000 debugless version oh wow.
YOU Genie)
its success!!!
14:12:13.870 Redline loaded system\redline.DLL library14:12:13.870 Redline.dll local verite path G:\PROGRAM FILES\FORMULA13\Verite.dll14:12:13.870 Redline.dll successfully load system\Verite.dll library14:12:13.870 No IndirectSRC14:12:13.930 V10003D.UC
video https://fex.net/s/vfzof6z
the demo ends and menu works, the next demo loaded also, works.
EDIT: your v20003d.uc different to what i have
A bigger whohoo!
Well done.
I think that's from the hercules thriller 3D.
[edit] v10003d. Ucis s from F1 drivers.
I'll clean up the code and remove unnecessary bits and publish the source, maybe on sourceforge.
The cleanup should make it a teeny weeny bit faster.
sharangad wrote on 2024-03-12, 13:06:I'll clean up the code and remove unnecessary bits and publish the source, maybe on sourceforge.
Tomorrow.
