Reply 20 of 53, by kotel
- Member
Roman555 wrote on 2024-04-18, 18:37:Any power problem can cause active RESET signal ! Usually ICH gets PWROK (power OK) signal from VRMs and sets PLTRST (platform […]
kotel wrote on 2024-04-18, 15:37:Re-flowing the mosfets did not resolve the issue. Any ideas?
Usually ICH gets PWROK (power OK) signal from VRMs and sets PLTRST (platform reset) into inactive state as an answer. Sometimes RESET for PCI bus (PCIRST) is controlled by a SIO chip instead of ICH.If I were you I would also check typical problems: USB data lines (using ohmmeter to measure resistance of the each line to GND rail) and loose contacts under CPU socket and/or MCH (to put something soft under a mainboard in a necessary place and press slightly a heat-sink before powering a mainboard on)
All USB lines are okay (I get 1round 15k ohms on data an more than 2k on 5v). Tried putting a metal backplate but same results.
DudeFace wrote on 2024-04-21, 16:05:ive had this issue with a couple of boards, i wouldnt have thought 2 buldging caps would prevent the board from working , i had an msi board with eleven 6.3v 1000uf caps, all buldging or leaking and the board still worked fine, tho caps can fail even if they look good so you can never be sure, those caps you have are close so i would try them out but i wouldnt run the board for long with them in. i think your problem is the bios, either a bad flash or its just corrupted for no reason which can happen. ive got a gigabyte board that does it every so often, ill plug it in and it turns itself on to a blank screen, it has dual bios probably for that reason, eventually i manage to get it to boot from the backup bios, then i reflash the bios. i've had other board do the same and its usually bios related, try a reflash or a new bios chip.
Later on in the post I replaced the 2 caps. Problem is with flashing the BIOS. I don't own any DIP32 EEPROM programmers and PLCC32 to DIP32 adapters. Not only that, but the BIOS is soldered on. I don't think a bad bios would cause the CPU to not go out of reset (and probably not get its power since it doesn't even get warm). Any ideas?
"All my efforts were in vain...
Let that be my disappointment."
-Kotel
