Reply 20 of 45, by mastergamma12
Put some more games on the machine.
file.php?mode=view&id=96982
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
Reply 21 of 45, by chrismeyer6
That's an excellent selection of games. Your guaranteed hours of fun.
Reply 22 of 45, by RedCharles
How does XP run with the six cores. Does it ignore five of them?
Reply 23 of 45, by Shagittarius
RedCharles wrote on 2020-12-29, 19:40:
All XP versions will run as many cores as you have, if you use more than one physical CPU I believe you need to get the enterprise version.
Reply 24 of 45, by chrismeyer6
XP home can use 1 cpu socket with multiple cores and XP pro can use 2 cpu sockets with upto 32 cores for 32bit and upto 64 cores with XP 64
Reply 25 of 45, by Srandista
One core limitation is for 98, XP can use up to 32 cores.
Reply 26 of 45, by RedCharles
Thanks for the replies.
And on the topic does XP ignore 8gb out of 12gb of ram then? Or does the 12gb of ram cause problems for XP?
I'm considering a similar build for myself.
Reply 27 of 45, by chrismeyer6
With 32 bit addressing it shouldn't matter if you have more than 4gigs since it can't address it
Reply 28 of 45, by Srandista
RedCharles wrote on 2020-12-29, 21:14:
It's the same, like with 98 and multi core CPUs. XP just ignores anything above 4GB. I have dualboot XP/7 on my laptop with 12GB of RAM, and XP just see and can use only 4GB. There's no problems with excess amount of RAM in XP.
Reply 29 of 45, by mastergamma12
It sees all 6 cores and 12 threads
As for ram, xp only sees 2gb's while 7 sees all 12gb's
Reply 30 of 45, by RedCharles
Have you had any compatibility issues with early 2000s games?
Reply 31 of 45, by mastergamma12
RedCharles wrote on 2021-01-01, 09:20:
Only game so far was Planet of the Apes 2001, graphic issues.
That game runs fine on my 98 rig.
Reply 32 of 45, by mastergamma12
I threw a USB 3 card in here and took out the wifi card as it didn't support XP so I'm just using a USB one now. Now the front panel usb ports run at USB 3 speeds. Also threw quite a few more games on XP and 7.
Reply 33 of 45, by mastergamma12
Ended up inserting another wifi card in.
Reply 34 of 45, by mastergamma12
I was able to get the leaked build of Windows 11 to run on here.
Reply 35 of 45, by chrismeyer6
Sweet. How does it run?
Reply 36 of 45, by mastergamma12
chrismeyer6 wrote on 2021-06-25, 22:18:
Thing flies
Reply 37 of 45, by Grem Five
Is there an advantage running a I7 980X over say a Xeon X5675?
Reply 38 of 45, by mastergamma12
Grem Five wrote on 2021-06-27, 11:41:
On this machine, very much, this board doesn't support Westmere Xeons period, I tried everything I could think of to get my W3680 to work and in the end, I ended up using a 980x.
Now if this was any other X58 board, then no.
Reply 39 of 45, by mastergamma12
I also tried the version of 11 that was released today, it still works.
