Trugg
Type: Shareware
Version: 1.01
File name: trg101e.zip
Status: file and contents not found
Original location: ftp://ftp.digitalworkshop.co.uk/pub/trg101e.exe
References: http://www.steffest.com/dxboulder/DXClones.htm http://www.digitalworkshop.co.uk/trg.htm
Here's a little something. One would think there'd be no problem finding the shareware version of this game, it's at RGB Classic Games and that would likely mean as clean and original as possible, right?
But it turns out that the ZIP has PKZIP's Authenticity Verification built in, and it reports that the ZIP has been tampered with:
I found a different archive (same contents plus one more file that also seems legit) on this Computer Shopper CD, again with PKZIP AV, and again it reports that verification failed upon extraction or testing (the -t command). Individual files pass the AV test so it seems to imply that either some other kind of damage has been sustained, or more files were removed from the archive.
The problem is, so far I only found the same copies as the Computer Shopper ZIP, or complete repacks with the same contents but no AV routine at all.
UPD: Apparently there was a newer version of the shareware, available from Digital Workshop's website, with the file name being trg101e.zip.
