Reply 20 of 91, by raymv1987
weedeewee wrote on 2024-12-23, 22:02:raymv1987 wrote on 2024-12-23, 19:20:weedeewee wrote on 2024-12-23, 18:15:an EISA card with jumpers to set IRQ & DMA.
How odd.
raymv1987, Do you have the software that supports this card ?
That was my thought. I've never seen anything like it. This is the exe that pushes data to the board itself.
https://www.dropbox.com/scl/fi/o5k9pcoim7rkax … t=uijsoydz&dl=0Is that all the software you have, a 32Kb executable?
Also, do you have more hardware for the transmission and reception parts ?
I do. I've got the appropriate model modulators and the end receiving adapter along with all appropriate cables. That's the full chain in terms of hardware.
There's some other bits of software. One reads a file that says when to broadcast (the exe I provided times out either way). One copies the broadcast data to the hard drive. Another plugs into the top serial port to push access data. That's more meant for subscriber info. Those all work fine. It's when I get to this last bit that gets stuck, due to the issues with the cfg/driver
