Old hardware giveaway thread.
Reply 1240 of 1348, by pshipkov
Micronics 386 motherboard.
Minor battery leak was fixed.
The 2-3 lines got reconnected.
Had to remove the top ISA slot to be able to trace them propetly.
BIOS gives one long one shot one long one short beeps, no repetition.
Wont have more time to deal with it.
Feels close.
If somebody wants to thinker with it - let me know.
retro bits and bytes
Reply 1241 of 1348, by Ozzuneoj
pshipkov wrote on 2024-05-27, 17:58:
Micronics 386 motherboard. Minor battery leak was fixed. The 2-3 lines got reconnected. Had to remove the top ISA slot to be abl […]
Feels close.
Have you tried a POST card or checked the tantalums? I'm tempted to grab it because it looks like a great 386 board, but I'm not sure if I'd be up to the task of diagnosing it beyond those troubleshooting steps.
Reply 1242 of 1348, by kingcake
Ozzuneoj wrote on 2024-05-28, 02:39:
Feels close.
It would be fairly obvious if a tantalum was shorted
Reply 1243 of 1348, by Kahenraz
Can they short without exploding?
Reply 1244 of 1348, by Ozzuneoj
Kahenraz wrote on 2024-05-28, 03:56:
Yes, they can fail open or fail short, and they can explode, fizzle\smoke or have no visible or audible failure. It's honestly pretty uncommon for any of those to happen from my experience, but with a board this old in such clean condition (barely used from the looks of it) it is more likely.
I just asked because that is something I would check if it hasn't been done already.
Reply 1245 of 1348, by kingcake
Ozzuneoj wrote on 2024-05-28, 04:06:
I have never seen one fail open. Ever. If it did, it wouldn't even be noticeable or cause a problem anyway, so that's a moot point to even bring up. If shorted it would absolutely smoke, unless the PSU tripped it's overcurrent and turned off. In either case, as I said, it would be extremely noticeable.
Reply 1246 of 1348, by pshipkov
If they short you will see and hear it. : )
I had POST card once but it rarely reported anything meaningful. It broke at some point later. Never got new one. Sorry.
The board is otherwise in very good condition. The problem can be something trivial, or not so.
My expectation for quick fix didn’t happen unfortunately.
Reply 1247 of 1348, by BitWrangler
While sometimes POST cards seem no more helpful than a "Magic 8 ball" or going through a box of fortune cookies, I have found them more useful than I ever thought they would be, even with a a weird BIOS you can't get POST code table for, purely relying on "make number go bigger" mode. It seems to be universal that the early codes are related to the core of the system, CPU/RAM, the middle codes the chipset and bare essentials and the later codes more to do with i/o and peripherals. So it kind of transforms fault finding from a kind of "Blind man's buff" game in like a massive empty warehouse with unknown number of participants, ( https://en.wikipedia.org/wiki/Blind_man%27s_buff ) to a game of "Marco Polo" which is in the confines of a pool and players have to call out "Polo" so you know they are there. In the first instance, it's easy to get frustrated and give up because you know very little about the number of issues to resolve. In the second you go kinda voice by voice and clear everything. If you get bogged down with a stubborn unknown fault code with unknown BIOS revision, you can "take votes" from all the code tables you can find, and drill down from most common specific issue to least, and it is probably gonna be one of those. All in all though, make number go bigger, you're fixing stuff, not completely in the dark, and eventually you get there.
edit: Actually, you can do better with an unknown revision if you use your early codes found to "narrow down the tree" of code tables that match, so by the time you're on your 3rd or 4th fault to clear you have one or two code tables that seem to match everything, and if a 5th code shows up, kapow, headshot, no messing around.
Reply 1248 of 1348, by pshipkov
Board is claimed.
Nodded in agreement with BitWrangler.
They can be helpful in some cases, or at least aid the process somewhat, but i find them a bit of a thin sauce. Not a must-have item.
Reply 1249 of 1348, by magicmanred
Anyone interested in AudioPCI sound cards? ES1370, ES1371, ES1373 chips?
Reply 1250 of 1348, by nfraser01
magicmanred wrote on 2024-05-29, 20:19:
Hi. Are you USA, Europe or elsewhere?
Reply 1254 of 1348, by nfraser01
magicmanred wrote on 2024-05-30, 18:55:
Thanks for asking! Made me realize I should update my profile so that it shows my location which I just did 😀
Me too!
Reply 1255 of 1348, by demiurge
I do collect PCI soundcards and I am missing the ES1371 version in the original ES form--I have the Creative branded version though.
Reply 1256 of 1348, by kingcake
pshipkov wrote on 2024-05-28, 19:49:
Board is claimed. --- Nodded in agreement with BitWrangler. They can be helpful in some cases, or at least aid the process somew […]
Board is claimed.
Yep I mostly use them to answer the question "is the CPU executing code" -- Unless you want to spend time disassembling the BIOS to see how the tests are being done, it can often be a red herring trying to chase a specific POST code.
Reply 1257 of 1348, by Mr.Batmensch
nezwick wrote on 2024-04-01, 21:17:
CRT was picked up
386 parts PC and Fujitsu HDD from a couple posts back are still available
is the 386 box still available?
Reply 1258 of 1348, by magicmanred
demiurge wrote on 2024-05-31, 02:20:
Did you want my ES1371? Or is it not the Creative branded version you're looking for?
ES1373 may be spoken for...
Reply 1259 of 1348, by pshipkov
a neighbor is letting go of these.
anyone interested ?
