Gotek like Optical Driver Emulator - Is it possible?
Reply 520 of 525, by keropi
phantasia wrote on 2024-09-15, 18:36:
keropi wrote on 2024-09-14, 13:19:
is there a version of zuluide that supports CDDA ?
It's in the works! 😀
https://github.com/ZuluIDE/ZuluIDE-firmware/issues/109
this is excellent news thanks 😀
Reply 521 of 525, by aperezbios
marcin512 wrote on 2024-09-14, 13:11:
Hi,
At current state, is it possible to install Windows 95 / 98 / XP from this device?
Yes, it's absolutely possible to install all of them. That has been possible for months now. I can't even count the number of times I've installed XP from ISOs at this point 😀
Reply 522 of 525, by aperezbios
Back on February 9th of this year, you wrote
weedeewee wrote on 2024-02-09, 12:24:
Bit bummed though about the zuluide seeming real, though not available and no github firmware page either.
I apologize for missing your original comment eight months ago, but I needed to point out that, If you take a look at https://web.archive.org/web/20240228194925/ht … ww.zuluide.com/, which is an archive of the public ZuluIDE website from February 28th of this year, 2024, you will see that it links directly to https://github.com/ZuluIDE/ZuluIDE-firmware. The description of the hyperlink states "Open-source firmware, licensed under the GPLv3"
Furthermore, if you examine the commit history for the zuluide.com website, you can see that this statement has been there since August 7th, 2023, which was added seven months before your incorrect statement was posted: https://github.com/rabbitholecomputing/zuluid … 7e91a902fce1a8c
I'm struggling to understand how that jives with the claim that there was "no GitHub firmrware page either" Additionally, a small quantity of people have been privately testing ZuluIDE since late September of 2023, and I decided to enlarge that pool in February, by initially making ZuluIDE available in an open beta, to those who were interested in early access to the product, as we worked to continue to bring it across the finish line.
Reply 523 of 525, by weedeewee
aperezbios wrote on 2024-10-18, 04:40:
Back on February 9th of this year, you wrote […]
That's a useless comment.
At the time, yes, there was a website and, at the same time there was no github with code, available for the zuluide firmware.
Hope that clarifies it. Both are moot points to complain about for a comment made 8 months ago.
In the meantime, I've already bought one several months ago.
edit: anyway, I just noticed your username. If that's really you, Thank you for your contributions to the ZuluSCSI&IDE .
Do not ask Why !
Reply 524 of 525, by aperezbios
weedeewee wrote on 2024-10-18, 05:03:
Thanks for your support! Hmmm.... It's very possible the repo might have still been set to private and I hadn't noticed... either way, doesn't matter anymore 🙂
By the way, we're releasing new features and bugfixes often, check out the firmware releases at https://github.com/ZuluIDE/ZuluIDE-firmware/releases, including one from last week.
Reply 525 of 525, by weedeewee
aperezbios wrote on 2024-10-18, 05:32:
Indeed, that's what I was thinking as well. 😀
I need more space to set up a 'permanent' setup for testing. I'm lacking in that department and time.
I've also got a few zuluscsis which are waiting for their machine.
If you've got a ZuluTime project coming out which can give a person more time to play around without any nefarious consequences, I'm already interested 😉
Do not ask Why !
