First post, by MrEWhite
- Oldbie
Now, after months of trying. I have gotten Blood 2 to run at a solid 60 FPS on Windows 8.1!
First, download the latest version of dgVoodoo 2. (http://dege.freeweb.hu) the latest version is currently dgVoodoo v2.41
Unzip the file to any location. Run dgVoodooSetup.exe
Go over to DirectX and turn off the watermark.
Click apply and click Ok to close the program.
Go to the dgVoodoo directory and go to the MS folder
Drag the D3DImm.dll and the DDraw.dll to your Blood 2 folder.
Launch Blood 2.
The game should run at the correct FPS now. Make sure to use no resolution with a height over 1000 pixels to avoid crashing! You can also force 8x MSAA if you wish.
UPDATE: Dege has released a patch to play the game at higher resolutions, check it out. http://dege.fw.hu/temp/Blood2ResPatch.zip
