First post, by stgiga
- Newbie
Hello once again! I have made ANOTHER SoundFont, this time focusing on Yamaha FM sound chips. You can download it here: It is 320MiB, and has MANY layers to EACH preset! I Googled each Chip to learn what went with it, and used MANY free Soundfonts for MOST Yamaha FM/Chiptune devices across MANY regions and platforms. The following chips in the below list are used to make this GM bank:
Notes:
Polyphony limited to 192 Voices (I did the math...)
Some outputs do multichannel beyond 2ch (Count channels for me...)
All required minimum Chips are used.
Try spotting them all ;}
Thank you for your patronage!
The Actual Chips:
1x Gashisoft GXSCC SCC Mode IC*
1x Yamaha YMF278 OPL4 Wavetable/FM IC
1x Yamaha YMF741-S OPL3-SA3L Chip
1x Yamaha YM2608 OPNA FM/PCM Chip
1x Yamaha YM2612 OPN2 FM/PCM Chip
2x Yamaha YM21280 OPS FM Chip
2x Yamaha YM21290 EGS Envelope Chip
1x Yamaha YM2154 RYP4 PCM Drum Chip
2x Yamaha YM2190x RYP4 Drum ROM IC's
2x Yamaha YM3012 RYP4 PCM Drum DAC
2x Yamaha YM3017 DAL2 DAC Logic IC
2x Yamaha YM3812 OPL2 FM Synth**
2x Yamaha YM3014B OPL2 FM DAC
1x Yamaha YM2203 OPN FM/SSG Synth IC
1x Yamaha YM3014B OPN FM/SSG DAC
3x Yamaha YAC513 OPL4 FM/Wave DAC
1x Yamaha YM3016 OPNA FM/PCM DAC
1x Yamaha YM2413 OPLL FM Synth Chip
1x Yamaha YM3433B OPNA PCM Splitter
1x Yamaha YSS225 EP OPL4 Effects Chip
1x Yamaha YRW801 2MiB GM Wave ROM
*1 GXSCC SCC Mode IC uses these chips:
8x Konami 2212 SCC Waveform/SSG IC***
2x General Instrument AY-3-8910 SSG****
**Each OPL2 chip is a stereo half.
***Codeveloped by Yamaha for the MSX
****The Yamaha YM2149F SSG will work as a Yamaha-made alternative to this SSG.
I'm Nonbinary and neurodivergent.
I use they/them. It can also be written as ᵺ㏟.
