Heads Up: Roland Sound Canvas VA VSTi Plugin!
Reply 740 of 746, by Spikey
The problem is that tracks which use the default drum kit STANDARD don't have a patch change for it on channel 10. Since the first track that plays upon loading uses ORCHESTRA, incorrect drumkits play during the game, and in fact anytime a STANDARD intended track follows a non-STANDARD one, if that makes sense.
If you reset the unit between every MIDI file externally (or insert a 001 program change in the offending tracks), they'll all play as intended outside the game.
I don't know about game versions, or SC versions maybe behaving differently and not showing/having the issue.
Reply 741 of 746, by stanwebber
just a heads up, i have gotten sound canvas va v1.0.3 activated under xp sp2, both 32bit and 64bit, so it's not impossible. you will need a sse2 capable cpu and the c++ 2010 runtime library. 64bit just worked, but 32bit required a 'portable' scva release before activation was recognized.
i used falcosoft's midiplayer v6.2 and/or vst driver v2.1.0 to load the vst.
Reply 742 of 746, by Karmeck
PhilsComputerLab wrote on 2015-12-28, 09:46:
Ok it seems to work now. […]
I used these two programs:
- loopMIDI
- SAVIHost
Here is a screenshot with Doom 2 in DOSBox 😀
Appreciated the video toy made on YouTube, using a windows tablet.
Reply 743 of 746, by Roland User
This bug some day will be fixed ?
Or Roland so treat people like idiots what think what can do only anti-pirate protection and at all not need fix bugs in each new version ?
Reply 744 of 746, by EmperorGrieferus
Roland User wrote on 2024-05-15, 00:08:
The first file is broken, so I have ZERO idea of what you're talking about. But since you're Russian, I propose that we continue discussion in DMs, shall we?
Reply 745 of 746, by Roland User
I'm packing in WinRAR 7.0 , maybe you try unpack with WinRAR 4 and older , if yes , so please , download and install rar version 7.0 or any version from 5.0 and latter ) or so https://disk.yandex.ru/i/PQk7dLbJkFosjA
Reply 746 of 746, by Roland User
Please answer to me , this realy so force diffirece in SCVA in mode SC-88 and real SC-88 https://www.youtube.com/watch?v=jSJu8u3QOmk ? Or in video used inserts and other methods of do better sound ?
