DOS 7.1 universal disk image is ready. It can be written to external internal drives, flash drives, SSDs, HDDs.
Tested configurations:
775/6800GT AGP+RagePro PCI/SB060
AM3/GTX580PCIe/motherboard sound
AM3+/GTX1060PCIe/motherboard sound
X99/GTX1650+HD6850/motherboard sound
Zen2/GTX1650+7900GS/SB060+motherboard sound
MasterBoot was a bit more difficult, but I stole the Hirens DVD boot sector. Linux loader loads the plain MBR, then the basic menu, and from there on the menued DOS.
4TB external SSD under DOS...yes, the modern Loew driver sees the capacity under DOS up to 32768TB. Of course, DosLfn also handles long file names.
The USB Image Tool pendrive for writing is free, but PowerISO (attached) for HDD/SSD is no longer available, and the image also contains copyrights, so I can't share it here, maybe privately...?
Of course, SBEmu works perfectly here as well, sound and video are ok, in protected mode the UEFI only video card is ok, and in real mode even the HD6850 - of course you need to slow down, CPUSpd, David Chee's excellent program, with which the modern machine also XT/ It can be slowed down to 386/486 speed.
After preparing a 4TB SSD, the result can be seen in MiniPWizzard under Win:
The attachment 71eefor4tb.jpg is no longer available
The remaining 3633GB can be formatted to FAT32, of course, easily with Master Loew's driver, and no GPT partition is needed.
Of course, DOS doesn't need such a large drive, I only tried to see if the master's driver works.
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
