Reply 60 of 1474, by crazii
- Oldbie
L4MD4 wrote on 2023-03-06, 04:11:I've gotten no sound. This is on a AC97 - Intel i915. SBEMU finds the chip "Found sound card: ICH AC97". Provided Jemmex is used […]
Provided Jemmex is used.
Wolf3d, is used for realmode test.
Dos Mplayer/Wolf4GW, used for protected mode test.
SETBLAST.EXE asks that settings be checked, when test is run.
On system power down/reboot, audio speaker crackles; as it only does after dos sound activation. So, something is working.
Edit:Each test after fresh reboot. Quake also tested.
Vendor 8086, Device 266e, Subsystem 834c10f7, revision 04
MS-Dos 7.10
MPXPLAY works.
MPXPLAY -SCT output: ICH : Intel ICH6 found on port : 18C0 irq:9 (type:ICH4, bits:16,20)What more useful information can I provide?
Actually ICH6 is never tested, only ICH4 tested. it might have problems, that's the case I'm mostly worried about: some boards are not working but I have no hardware to debug it, just have to review the code to find any problem for now. 🤣
Toshiba Satellite Pro 4300 - YMF744, Savage IX
Toshiba Satellite 2805-S501 - YMF754, GeForce 2Go
IBM Thinkpad A21p - CS4624, Mobility Radeon 128
main: Intel NUC11PHKi7C Phantom Canyon: i7-1165G7 RTX2060 64G 2T760PSDD
