First post, by zapblast
Hey there,
Here is my question and issue:
Using an old dos running, with a turbo speed set at 33. There is a problem with trying to run the game.
Some background:
It is the European budget release takie version from 1995 that is a rerelease of the non-talkie floppy game from 1991. So audio files run on the cd but everything else is installed that’s the only decent way to play. It also has a windows option but that’s not useful I’m using an old dos system. Dos 5, Sb 16. It works with basic PC speaker or no sound perfectly but I put the soundblaster or alib option and soundblaster effects together ( which is the best way and I have the hardware) and it:
After entering the game In dos it stops and says I need 3264 bytes of free memory. Then it will randomly say 7000 at times or work for a bit but it mostly says 3264. Only option is to use extra memory in the original setup. ( it doesn’t do with with pc speaker or no sound, it runs)
What should by done to get the game to work by adding more free memory in the config and Autoexec? I removed all installed games and tried to rem a bit of stuff. What else should I do ? I ONLY want it with soundblaster for effects and audio
I've tried moving tweaking the sb16 IRQ 10 to IRQ 5 but that has no bearing on this issue, and it causes errors.
I’ve attached pics of all you need to know in this wetransfer link :https://we.tl/t-etNFG5s1ey
