Reply 5880 of 6015, by Shagittarius
- Oldbie
Joseph_Joestar wrote on 2024-04-06, 19:03:Shagittarius wrote on 2024-04-06, 18:44:Ok, just tried out the save. I tried each machine with the settings above except for resolution where the Win11 machine was at 1600x1200. No slow down on the Win11 or WinXP machines. The Win98SE machine did slow down but it slowed down regardless of the Vertex buffers being on or off and like I said before the 9800 already runs at closer to 30FPS normally. I think what I'm seeing with the 98SE machine is evidence of what you are seeing, but I cant see it with the more powerful machines.
It's likely that more powerful hardware can just brute force through the issue.
In my case, lowering AA was enough to get rid of the slowdown, so I'm guessing even a slightly more powerful GPU wouldn't have any problems.
On an entirely different note, I personally can't stand AA, I never run it. To my eyes it just makes everything look blurry, I'd rather have jaggies. =) At least old style AA, the AI style AA is a different story.
