First post, by Vipersan
So ..I'm hoping this mini project is considered suitably retro or classic.
We all know modern TVs ship with the new standard of HDMI ..and rarely have Component I/O ie RGB..
This is something the Xbox classic does rather well ..
it does of course have component out ..
But Wii component to HDMI adapters can be had for a few ££s from china..
These of course are fitted with the proprietory Wii connector ..
So I bought one with a component lead ..R G B plus audio for about £6 all in .
Cracked the unit open and removed the wiii connector ..
I then cut the component read leaving a few cm of wire ..
sadly this only provides R G B ..left and right audio ..and ground ..
..but we need 5volts to power the Wii pcb ..so removed the component cable shroud and found pin 13 which _does_ carry 5v from the Xbox ..so an additional wire fitted ..
These wires could now be connected to the Wii adapter pcb where the proprietory plug had been removed.
et voila ..we now have an Xbox hdmi adapter..
See photos for details..
Sorry some are out of focus ..but you do get 720p hdmi out ..plus audio to the TV.
My Xbox classic will look a bit unconventional ..on account many years ago ..I built it all into a Bush DVD player case ..
I will of course need to construct a protective box/case for the adapter ...all in good time.
rgds
VS
