Are CF cards my problem or...?
First post, by Cooljerk
Concerning retro PCs and Amiga builds, the prevailing advice given online regarding harddrives these days is to go with a CF kit. From youtubers to random forum posters, I've seen this recommendation over and over again. And for years, across a variety of operating systems, I've tried this, and in my experience CF cards are a very poor medium to replace a reliable harddrive. Only problem is I never see anybody else report the same sort of problems that I've had, so I've never been sure if the problem is with CF cards themselves, or something else I'm doing that I haven't been able to put my finger on.
The problem with CF cards I've found is that, for a lack of better words, they eventually just degrade. What I believe is happening, but I can't confirm, is that bits of data on the cards themselves are either becoming corrupt or just outright changing, and I believe this is exasperated by access. I've noticed a general pattern, regardless of platform or operating system, where for the first few days (or even months) after getting everything set up, it'll work fine, and then slowly crashes will start happening until the card is basically useless.
For example, I have an MS-DOS 486DXII build, soundblaster 16, trident video card, yadda yadda. I had purchased hundreds of CF cards in a bulk lot, and my intent was to format each of them and give each one an MS-DOS install, with a single game installed on every card, set to auto boot. Coupled with a front mounted CF card reader, this would let me treat individual CF cards like game cartridges - just pop them into the DOS box and turn on and bammo, you're in the game. And this all worked, and for about a year I could enjoy my dos games. I figure because each game was a different CF card and different install, and I played many games, it took longer for the pattern to set in, but eventually each game would become corrupted. Ini files would become full of gibberish text or otherwise. Eventually, every card failed. They were bought in a lot on ebay, lots of random builds and manufacturers, but they all eventually failed.
I also have a couple of windows 95 and a windows 98 builds. These followed the same pattern - upon install they worked great, but soon after windows would begin to crash or lock up, and then eventually refuse to boot at all. I figured a modern operating system like windows probably accesses the card much more often that it'd make the symptoms show up sooner.
Lastly, I have a couple of Amiga 1200s and an Amiga CD32 with an SX-1 expansion. Again, CF cards are recommended everywhere, and a workbench installation has worked alright on these machines. Yet, once again, after a while of use, I'll get crashes and locks, and eventually failure to boot.
Has anyone else noticed this happening? I almost wonder if many people who recommend these cards just don't really use their computers very much, or am I doing something wrong? Assuming it IS the CF cards, what is the best option regarding harddrives for old machine? SATA to IDE kits? SSDs? I'd really like to have a discussion on this.
Anybody want to chime in?
Reply 1 of 61, by halfmoon
I've had a lot of issues with CF in my DOS Pentium 2 machine that I tried them on. I eventually switched to an IDE->SATA converter (a few bucks on ebay) and use a 120GB Intel SSD and it's been working perfectly ever since. With the CF, sometimes it just wouldn't boot the system or have some random issues, and even playing games like Doom, it would freeze for a noticeable amount of time mid-level when it went to access the drive. My CF cards weren't too heavily used and I bought them new, so I doubt wear was the issue. I do use IDE->CF adapters in an NEC PC-9821 and Amiga A4000 but I don't do a lot of writes (at least not yet) and it seems to be working fine for now but I can't say how long that will last for.
I'd recommend you try the IDE->SATA converters and see if that solves your issues.
Reply 2 of 61, by Tiido
If you're getting weird corruption like that with everything the chances are your adaptors are garbage, CF is sensitive to mechanical connection and if get specific bits go bad this is most likely the problem. I haven't had any sort of issues with CF myself, I mostly use them in laptops. CF adaptor should also have a capacitor on the power pins too near the socket and the cable should be fairly short. They're not meant to drive long cables like IDE HDDs are made to drive.
*wonders if you're the same Cooljerk I know* 🤣
Reply 3 of 61, by Jo22
No issues with CF cards so far.. I'm using quality CF-IDE adapters with voltage regulators and cheap ones (with diodes added manually).
Tiido, you're remembering me of an older Compact Flash FAQ site! 😀
"How to kill CF cards ? Easy... Start a write, and immediately (less than 1 second or so) do a system reset."
Source: http://www.pcengines.ch/cfwear.htm
Reply 4 of 61, by derSammler
I'm using CF cards in many of my retro systems as well. The most important lesson to learn: never *ever* buy used CF cards - unless you need them for testing only. And don't buy cheap ones either. Unlike hard drives, the number of writes to a Flash cell is limited by physics and each write damages the cell so that the data lasts for a shorter period of time. Used CF cards may have already reached the allowed number of writes and there is no way to verify that. Just stay away from used cards.
Buy good brands (SanDisk, Kingston, Transcent e.g.) and - if possible - industrial grade cards. Those use SLC instead of MLC, which can takes 10x as many writes and reliably is much higher. Never fill a CF card with more than 50% of data, otherwise the wear leveling becomes ineffective. And when using Win9x, install enough RAM so that you can disable the swap file - or create a separate partition for it. Obeying to that, I have systems that run from CF cards for more than 4 years now. And should one fail, I made images of all cards after the system was fully set up and can restore it on a new card within minutes.
Reply 5 of 61, by kixs
I use CF cards all the time. The oldest installed is for my A1200 that I setup sometime around 2010. So it's in use a few times a year since then and still haven't found any problems with it. It's 4GB Sandisk Ultra.
For PC DOS/Win95 setups I use smaller CF cards (256, 512 and 1024MB). But I change files more regularly (adding files, deleting...) and I still didn't notice any problems with them.
I did read somewhere that cells in SSDs will degrade slowly if not in use regularly.
Reply 6 of 61, by derSammler
All Flash cells do. Imagine it that way: a Flash cell is like a bucket. Storing a bit in it is like filling the bucket with water. But whenever doing so, a pinhole is stabbed into the bucket. Now one pinhole is not an issue and you can still see that there's water inside much later, so the information is still intact. But the more pinholes you stab into the bucket, the faster the water runs out. Eventually you reach a point at which the bucket becomes unable to hold any water.
When using a Flash-based storage device regularly, the controller inside will detect degraded cells and copy them over to spare cells.
Reply 7 of 61, by Jo22
This thread reminds me of an older thread in which we discussed wear-leveling of SD cards.
It was Using a SD card instead of hard disk
Shamino raised some very interesting points in that respect, IMHO.
Also notable is the nasty issue of filesystem/partition alignment. While NTFS can be placed nicely in matching pieces,
FAT and FAT32 are another matter. From what I read, FAT can be off even though it was aligned to 4K boundaries
by using GParted or other tools. Doing a correct alignment here is quite difficult and has to be measured manually
by calculating starting addresses, length of FAT(s), cluster size, etc.
Edit: What I'm referring to is the socalled read-modify-write.
It also happens with modern HDD drives, because they now use 512e (512byte emulation on 4K tech) or 4Kn (native 4K),
but nolonger operate with 512byes/per sector (last drives of that kind were made in late 2000s).
Such a read-modify write causes performance to driop by 50% on HDDs and is even more stressing for SSDs.
In essence, write amount gets doubled which causes huge wear in comparison to a normal write.
Reply 8 of 61, by derSammler
Which ones? Alignment will only affect write speed. You would need to ensure not only the correct start address but also that the cluster size matches the block size of the Flash memory. Since you can not freely manipulate both and may not even be able to tell the block size of the Flash memory, it's something no one really needs to care. That's more of important for real SSDs, not for storage cards.
And leaving free space is *not* overprovisioning. Overprovisioning is pre-defined by the factory. The space reserved for that is invisible to the user. Only the overprovisioning area is used to replace bad blocks. Wear leveling on the other hand works with free blocks in the user-visible area. When a block for writing is requested, the next free block with least writes to it is used. Though it depends on the controller. Some keep track of the number of writes, others only distinguish between "free" and "used" and select one free block randomly. Still, leaving free space is important, since distribution of writes is more evenly the more free space is left (obviously).
Reply 9 of 61, by canthearu
You shouldn't have to leave 50% free on a CF card to have it work properly.
CF cards do NOT have the TRIM feature, so there is NO way to release blocks that have been written by the OS back to over-provisioning once the OS stops using them. So it doesn't really matter how much free space the OS sees, because the CF card has no way to know which blocks are in use and which are not.
Reply 10 of 61, by derSammler
This is true for older cards only. TRIM was added in 2010 with CF 5.0. But anyway, that's why you should better not use more than 50% of the card (and put the swap file onto a separate partition). This way, it takes quite a bit of time before you run out of unassigned blocks. If you fill the card up to 100% once, there's no way back except by flushing the card.
Reply 12 of 61, by derSammler
CF cards are still current-tech. Just like with SSDs, the controller used by the card makes the features. TRIM was added to the standard in 2010, for example.
Reply 14 of 61, by canthearu
Ah, didn't know about that.
Still, DOS does not use TRIM.
Reply 15 of 61, by Jo22
I'm out. 🙁 The discussion gets a bit too hot for me (I don't want to start a fight or something by saying something wrong).
Just let me quote a last line from that page a linked to before.
How well does the wear leveling work ? CF controllers perform wear leveling to spread the erase cycles across multiple blocks,
so frequently written blocks such as directories or file allocation tables don't wear out prematurely.
Wear leveling algorithms are proprietary and undocumented - "secret sauce".
Edit: edited.
Reply 16 of 61, by Cooljerk
SMALLLLL world, had no idea you posted here as well 😜
Thing is with my CF cards is it's not a single adapter, across all these PCs I've used a variety of CF kits and adapters and they exhibit the same sorts of problems. Specifically with the Amigas, in fact, I used a kit from AmigaKit that came specifically with a "plug and play, no hassle" CF card already formatted for the machine. I see them recommended in lots of videos.
And ya, I'm using short cables, usually maybe about an inch or two long.
EDIT: For benefit beyond "yup, it's you" 🤣, would you be able to recommend a CF adapter and card brand that isn't crap? I'm interested in giving all this another go.
Reply 17 of 61, by Tiido
This is strange indeed, then perhaps a number of those cards are used to death or something ?
Hahaha, small world indeed 😜
I have only used brand new UDMA capable Kingston cards with lifetime warranty, never got any problems. These are the adaptors and cards I have had no problems with :
http://www.tmeeco.eu/BitShit/PCschit/CFstuff.jpg
I've used these for years without any sort of problems.
Reply 18 of 61, by LSS10999
You certainly need good quality CF adapters to make cards work properly for an extended amount of time, and also make things like UDMA and IDE 80 conductor detection work as intended. UDMA usually works, but some commercial-grade CF cards don't implement it properly that would throw errors until the system puts the card to PIO modes when connected to a CF-IDE adapter. The IDE 80 conductor detection often doesn't work well with adapters that plug directly to the IDE slots rather than through conventional IDE cables (the issue also affects some IDE DOMs), limiting speed to UDMA/33.
Most CF adapters have jumpers for voltage and slave/master settings. As for voltage, whether 5V or 3.3V works best depends on the card itself, but most cards should work under either voltage as per CF card specification (provided the card followed the specification well).
You probably need to look for some industrial-grade CF cards that are properly designed for IDE use. Commercial-grade cards are often configured as "Removable" (which causes issues with modern Windows) and don't implement all the IDE functions properly (which might lead to issues faster). This depends on the manufacturers, some follow the CF card specs well, others don't. AVOID SanDisk CF cards at all cost. Those cards have all kinds of issues and SanDisk were trying their best to discourage users from using them as IDE drives.
At one time I did have a CF card misbehaving on a card reader, that the text files copied to and from the CF card became messed up (the text became something different from the source file), and turned out some pins on the card reader were bent and the card wasn't connected properly. CF slot pins seem to be really fragile that they get loose or bent very easily.
Reply 19 of 61, by shamino
I've only once attempted to use a CF card on a PC. It was a Kingston 8GB card that I bought new at a major retailer so I'm pretty confident it was legit. I made a 2GB FAT16 partition, and for whatever reasons, I installed Daggerfall three times and on the 3rd try I started getting disk errors. I was pretty disappointed.
I have a couple Transcend 4GB cards that I meant to use for a low power system that was dedicated to a Windows application, but I got so bogged down in the minutia of how to set things up that I just used a laptop hard drive instead. The need has passed and I never used those CF cards.
I'm a bit prejudiced against cheap Flash devices like CF, SD, thumb drives, game system memory cards, etc. I've had enough problems with them not to trust them in general, but to be fair my attempt with CF was very short and with only one card. If I wanted to judge CF fairly then I should try it again.
But I don't see much need anymore. 2nd hand SSDs are cheaply available nowadays so I'd be more inclined to use those. That does add the need for SATA->IDE conversion which I've never gotten into, but from what I've read it doesn't seem like this is much of a problem. Maybe it is for an Amiga, I have no idea.
In your case though, I understand you had a large supply of CF cards already and so it makes sense to want to use them.
I wonder if the lot of cards you purchased might be hacked or fakes. What I mean by "hacked" is that some sleazebags will reprogram CF/SD/etc cards to report more capacity than they actually have, and then resell them as larger drives. Eventually they corrupt themselves because they're trying to put 10lbs of storage addresses in a 5lb bag.
In case it isn't already clear, I just want to point out that in order to leave free space that will actually be treated as "free" from a Flash device's point of view, that space needs to be left *unpartitioned* so that the OS never targets it for a write operation. When the OS "erases" something, it's really just another write operation and the Flash device doesn't know it's significance. It will still think that any logical address that has been the target of a write operation is still associated with important data. Thus whatever physical Flash cell(s) that were previously associated to that logical address will continue to be maintained when they don't actually need to be.
TRIM solves that problem, but obviously old OSes like MSDOS don't send TRIM commands.
A workaround is to TRIM everything in some modern OS (or start with a new drive), and then do something to ensure that some portion of the logical addresses will never be used. Leaving some space unpartitioned accomplishes that.
I'm surprised if there's any distinction between user-visible and overprovisioned space. Surely it must be a common pool. The drive has say something like 34GB of Flash storage, and then the controller is programmed to show the user that they have 32GB worth of logical storage addresses that can be targeted. Each write to some logical address (LBA) leads to an association between the LBA and some physical Flash location which could lie anywhere within the 34GB of actual space. Unless CF cards have a more fixed mapping scheme than I'm presuming.
In that example, the factory overprovisioning would ensure that there is always at least 2GB of unallocated Flash. If physical Flash storage gets close to full, it leads to a thrashing effect when the drive needs to rearrange data (ie write amplification). This kills the drive's performance and longevity, so the 2GB overprovisioning keeps that somewhat in check. But usually the factory overprovisioning is skimpy because it's "wasted" space that can't be advertised to the consumer.
So-called "enterprise" SSDs (and I assume CF cards) have more factory overprovisioning than consumer drives do, but you can get a similar effect by doing it yourself with partitioning.
If the user only partitions 20GB of space, then the other 12GB worth of logical addresses will never be targeted for a write operation, so in effect, you've increased the over-provisioning by that amount. As long as you never touch those unpartitioned addresses, then the effect is as good as if it came from the factory as a "20GB" drive with 34GB of physical Flash capacity. It will never get full enough to appreciably degrade, even without TRIM.
However, I'm really thinking of SSDs here. I don't know how dumb CF cards are. If they have a more fixed mapping between LBA -> physical Flash, and can't map the locations with as much flexibility as I'm assuming, then maybe they don't respond as well to this.
Interesting. I had no idea there was any form of non-SSD Flash devices that had this feature. I'm glad somebody did it.
