First post, by Matrolisk
I have an Asus K7M motherboard that was pulled from a known working system.
When I power it up now the HP logo image will display but that's all. I also can't get into the bios setup either.
I was using a newer psu but swapped to it's original to test that with no change.
I've tried swapping the ram but that didn't work.
I've reseated the slot cpu.
I pulled and reinserted the clock battery and shorted the pins to clear cmos.
I'm not sure what else to try.
That computer it was in had not been used in a while but booted fine the last time it was used.
