Reply 40 of 41, by Sphere478
- l33t++
TrashPanda wrote on 2022-01-19, 05:57:bloodem wrote on 2022-01-19, 05:46:They are probably running at AGP 2x, which is a no-no for most SS7 boards. You can confirm this with Everest/Aida32/Aida64. You […]
Living wrote on 2022-01-18, 23:30:AGP its too picky and Bsods with the majority of the Vcards (tnt2, geforce 2 and 4)
You need to force AGP 1x - there are various ways of doing that: either by using some earlier VIA 4in1 drivers and installing the AGP driver in “normal” mode (NOT turbo mode), or by applying some registry tweaks available for nvidia drivers.Please note that disabling AGP 2x in the BIOS settings might not always work, depending on the motherboard/BIOS version, so it’s better to always confirm the AGP speed with the aforementioned third party software.
Did anyone ever figure out why SS7 hates AGP 2x ? was it an electrical issue or just shitty chipset and drivers ?
I’m thinking bios or mobo design.
I finally found a mobo that works with full agp settings freeway ti5vgf. Having to use single sided memory sucks though
