PowerPie5000 wrote:
I don't want XP on my main system and it'll still have issues with older XP games due to multi-core problems etc. I think a fast single core CPU is good enough for old WinXP games. Later XP games usually work fine with Vista/7 and made use of more than 1 CPU core... I can run those games on my current i5 3570k gaming PC 😀.
I think the Athlon 64 CPUs were probably the best when it came to single core CPUs (better than the P4)... Maybe i could throw together a cheap A64 PC, or just buy and old OEM one and modify it a bit?
You hit the nail on the head in para 1 of your post. Personally, I wouldn't waste my Sandy Bridge-e and Ivy Bridge systems running an antiquated OS. Don't wanna dual boot either.I'd just keep it in a retro rig for nostalgia and good ol' times sake.
My personal aims with an XP rig are as follows:
It should have enough CPU + GPU power to handle stuff up to 2006 in full HD, i.e. play XP era defining games like HL2, Far Cry and FEAR. From 2007 onwards games started supporting DX10 widely (e.g. Bioshock/ Crysis), multi-cores and would run best on a modern Win7/8 machine.
Importantly, it should be something I can connect with and feel a certain nostalgia for.
Perhaps I can share my personal experiences based on some of the XP rigs which I've owned to help with your decision. Draw what you may from them.
1) Pentium 4 Northwood 'B' @ 3ghz, SiS 645 chipset, 1.5gb DDR 333, Nvidia Ti 4600, 80gb IDE hard disk. A circa 2002 period correct build. This could handle games up to 2003 brilliantly, except HALO. Struggled with 2004 titles like Far Cry and HL2, which were only playable on low settings @ 1024x768. Conclusion: Usable for games up to 2003, but it fails the HL2 and Far Cry XP era defining limited useful timespan due to cpu and gpu bottlenecks.
2) Pentium 4 Prescott @ 3.6ghz, 865PE chipset, 3gb DDR400, 160gb SATA, Nvidia 6800GS. This was much faster than you'd think compared with rig 1), the HT and near 1000mhz system bus really held with making the system feel modern on the desktop. CPU performance was around an Athlon 64 @ 2ghz, which is OK but I felt it still bottlenecked the 6800GS a little. Played HL2 and Far Cry @ 1280x1024 near 60 fps. FEAR at medium/ high settings 40+ FPS. Black & White 2 was OK. Forget about running Oblivion or Call of Juarez from 2006 on this. Conclusion: Usable for games up to 2005. A more powerful AGP card such as a X1950, 3850, 4650 would have fixed this easily making it usable for games until 2007 even.
3) Pentium E5700 @ 3ghz, P965 chipset, 2gb DDR2 800, Nvidia GTS250, 500gb Samsung F3. This played everything up to 2009 titles as you would expect.
4) X3320 @ 3.0ghz, P35 chipset, 2gb DDR2 800, Radeon 3870X2. Even better than the above.
5) Q6600 @ 3.2ghz, P45 chipset, 4gb DDR2 800, Radeon 6850. Very, very fast, everything playable up to present day.
If you like Core 2 systems than go for them as the platform is really a fine one, without complaints technically.
6) Athlon 64 @ 2.4-2.5ghz, NF4 chipset, 2gb DDR400. I owned 3 such rigs, one with an ECS A939 NForce4, second with a DFI NF3, third and last (so far!) with an Asus A8N-SLI. I used mostly Nvidia 6600GTs with these systems, the last one (A8N-SLI) I used 6600GTs in SLI. The cpu was more than adequate for anything up to 2007, but the 6600GT was a really limited video card even in SLI.
7) Athlon 64 X2 @ 2.7ghz, AMD690 chipset, 2gb DDR2 667, 8800GT. Nice cpu good for everything up to 2008, the 8800GT was really a perfect match for it. Conclusion: A64s should be paired with video cards better than 6600GT/6800GT. Anything less than a X1950 is a waste.
😎 Athlon 7750 @ 3.1ghz, 780 chipset, 4 gb DDR2 800, 8800GT. This cpu is really a cut down Phenom I. Better than rig 7), comparable with Core 2 power and finally allowed my 8800GT to breath freely.
One of the hard disk setups I ran with my A64 systems consisted of 4 SATA hard disks in Raid 0. This resulted in ridiculously fast boot-up and game loading times - fun!
These are just some of them.
