First post, by Kahenraz
Spotted this on eBay and found it very amusing.
The attachment IMG_20210907_050722.jpg is no longer available
Reply 1 of 8, by PC Hoarder Patrol
Kahenraz wrote on 2021-09-07, 09:08:
...on a flat plate 😀 😀 - I have a couple of these on IBM 1Ghz P3 / 133MHz slot 1s
The attachment Molex 37085 SECC2.pdf is no longer available
Reply 2 of 8, by Kahenraz
One advantage I can see is that they are probably very light as an arrangement of fins and would pair well with a slocket.
Reply 3 of 8, by The Serpent Rider
Small equals noisy cooler. Can scuff crystal during installation too.
Reply 4 of 8, by Kahenraz
Standard cooling fan so means it is easily replaceable. A resistor or fan controller can also be used to adjust the speed to taste.
Reply 5 of 8, by Tetrium
Kahenraz wrote on 2021-09-07, 09:18:
They are indeed very light. I doubt these will cool very well though.
Btw, these 'heat sinks' can be taken apart, those fins are not a single mass but it is kinda folded together and it will come apart if you try to disassemble it so be careful when trying to take it apart 😜
An interesting design for sure.
My retro rigs (old topic)
Report spammers here!
Reply 7 of 8, by Kahenraz
Oh ho! There is a copper slug there too? Sneaky.
