First post, by badflame
the intro of the game, and in general all videos, have some black horizontal lines on screen.
Any chance to remove them?
Thanks.
Reply 1 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Try the attached workaround program, just run it in DOSBox before running the game.
Other games, particularly those developed by Synthetic Dimensions, have the same issue where the workaround may help.
BTW, Chronicles of The Sword uses CD-audio channel control for speech, and you'll need an SVN build of DOSBox for that to work as intended.
Reply 2 of 6, by badflame
ripsaw8080 wrote on 2024-06-01, 11:59:
Thanks, mate. Once again you have solved my problem.
Regarding the voices, they work correctly for me.
Let's see if you can come up with a solution for the flicker in "The Gold of the Aztecs": The Gold of the Aztecs flickering (VGA mode)
Reply 3 of 6, by torpedo
Thanks, it works correctly. Just out of curiosity, is this your own program? Or is this from some collection like garbo to help with demoscene programs?
Reply 4 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
torpedo wrote on 2024-06-11, 17:44:
I made the workaround program to test a solution for what is possibly an emulation issue in DOSBox. Is the program helping somewhere other than in DOSBox?
Reply 5 of 6, by torpedo
ripsaw8080 wrote on 2024-06-11, 22:23:
No, I only needed it for DOSbox. Specifically for Druid:Daemons of the Mind. The thegreatcodeholio also provided an alternative fix
Druid: Dæmons of the Mind
But this vesa program is useful for other forks.
Reply 6 of 6, by Rincewind42
Would you be so kind as to list those "other games" not developed by Synthetic Dimensions that also exhibit the issue? Thank you.
DOS: Soyo SY-5TF, MMX 200, 128MB, S3 Virge DX, ESS 1868F, AWE32, QWave, S2, McFly, SC-55, MU80, MP32L
Win98: Gigabyte K8VM800M, Athlon64 3200+, 512MB, Matrox G400, SB Live
WinXP: Gigabyte P31-DS3L, C2D 2.33 GHz, 2GB, GT 430, Audigy 4
