First post, by tincup
New member. I just upgraded from a 7800GT nVidia driver system that ran VDMsound games [Grand Prix 2], OpenGL [Glquake etc.], Build engine games [Redneck, WW-2 GI, Duke Nukem, Nam, Blood 1 etc.] just fine - to an ATI 5770 rig with the latest driver v10.12
None of the above categories of games work though I did solve most of the GL issues by dropping an old opengl.dll into each GL game folder, but have not contrived a fix for the others.
Any suggestions? Thanks..
Reply 2 of 4, by tincup
Thanks DF
the link was to a discussion of setup issues that I had well in hand before the upgrade. I also want to rule out dual-core/hyperthreading as a cause and will disable on a by/app basis to see if it restores anything. 🤣 yes i'm sticking with XP at least for the next 6-12mo. Right now I'm installing an AMD 555 with 4gb/1600 ram - maybe it'll finally be enough to run more demanding games in DosBox.. will give VPC-07 a shot too.
Reply 3 of 4, by Yushatak
VDMSound works just fine on 32-bit Windows 7, by the way.. I use it on my netbook for games that the machine can't handle in DOSBox (later ones).
