Reply 280 of 571, by myne
Nah, doesn't work for me.
Windbg output below:
I built:
Reply 281 of 571, by BEEN_Nath_58
myne wrote on 2024-07-20, 09:26:
I am a little confused. I can see an access violation in Disasm.dll. When did this start happening? What is the earliest mw2installer or DxWnd package that worked?
Reply 282 of 571, by myne
I was just attempting to update the dxwnd package from the one bundled with the installer. That's the one that worked. I haven't checked the version.
I built:
Reply 283 of 571, by Deffnator
May i suggest updating the package for mercenaries with 1.1 patch for the 3dfx release?
Reply 284 of 571, by myne
I never got the mercs patch working 😒
The attempt (files) are in the second link in the first post if you want to see if you can figure it out
I built:
Reply 285 of 571, by BEEN_Nath_58
Deffnator wrote on 2024-09-15, 23:28:
Give me a week to test it, busy days...
Reply 286 of 571, by Deffnator
By the way another thing, which needs to be checked with mech2.org discord if anyone here has contact with them
back in the days of the xp patch for mech 2, there it was a resolution hack for meck 2 that permitted higher resolutions for mw2 and mercs, but due to win 8 and 10's release that was lost, their discord may remember the res program.
you could simply click and chose any res and execute the game, it was a better alternative to the _mw2res and _titanRes files
Reply 287 of 571, by BEEN_Nath_58
Deffnator wrote on 2024-09-16, 13:40:
If it can be put on the MechVM installation of the game, there's still a chance it can work on Win8+. No promises, just speculation as the game still works with MechVM on Win8+, although DxWnd hook is needed to run sideways.
Reply 288 of 571, by mrgamerwood
Hi I am new here, but i have been trying to use the mw2 installer that is linked in myne's signature to install mechwarrior 2 titanium edition on windows 10 but it is not able to install the version of mech 2 mercs i have in my disc drive. Does anyone have any ideas? I have attached the picture of the error that also shows i have the disc in my drive
Reply 289 of 571, by mrgamerwood
I also took a look at the powershell script and wondered if my version of mech 2 mercs might not be listed here. seems like this section looks at the cd in the drive and selects a install method automatically based on the cd.
Reply 290 of 571, by myne
Yep. That's exactly it.
Copy, paste and modify one of the existing Titanium mercs lines to match and it will probably work.
Then paste the modded script here if it works.
I tried to make the script understandable by anyone with basic knowledge - because I and Beennath can't always fix everything and more eyes =better results.
Change the resolution with the dgvoodoo exe.
It'll do 4k for the engine, but not the HUD.
I built:
Reply 291 of 571, by BEEN_Nath_58
It looks like there is none for the Windows version? Only the DOS with some DLL edits? Even Vogons has denied the existence of any for Win
Can you check if this is the game you meant? (run the splash.exe of your game)
Reply 292 of 571, by Deffnator
So here is an update, the 3dfx installer for mercs doesnt work here at all, even the old cd i had as "other means", so it must be hardware related issue due to the 2600x i am using.
But the 3d positional and 3d enhanced version works as mech2.org 1.1 patch for it which has the mechprep i spoke earlier that changes the game resolution, which makes me wonder if its possible to use mechprep alongside dxwnd to increase the game res to full hd, or have dxwnd use dgvoodoo's own ddraw to crank the res to full hd.
Also Audio works because i am dumb and i forgot to set dxwnd to audio files.
The attachment Mech2edfx aspectratiocrt on msaa8x lanczos3.png is no longer available
Here is Mech 2 3dfx in its all glory and "wireframe" mode, all is left now is the hud transparency issues, but is working flawlessly.
Though a .MAP edit to add modern KBM controls would be necessary.
Reply 293 of 571, by BEEN_Nath_58
Deffnator wrote on 2024-09-17, 15:06:
MechWarrior 2 3Dfx Edition doesn't load HUD in mission as well as pause menu ?
Reply 294 of 571, by Deffnator
BEEN_Nath_58 wrote on 2024-09-18, 10:21:
i mean that the hud's transparency issues i reported it to dege and related to another game, which is Uprising, but i fixed myself later.
As for mech 2 3dfx, this is what i meant
The ui is reacting to the surroundings due to this transparency issue.
when i activate external camera, the ui is has no transparency issues due to the black color in the background.
Edit, i saw the problem at the other thread, and i think it is related to the issue i found with uprising.
As for Mercenaries with the mech2.org patch, i decided to use dgvoodoo2 ddraw and it works in full hd and higher res and scaling, the only issue is the menu flickering, but it is in full hd
Reply 295 of 571, by Deffnator
So i decided to install reshade now to see how it is with the games
Both MercsD3D and MW2 3dfx works greatly, but Ghost Bear Legacy has a strange issue which is more related to dgvoodoo2 on which the screen flickers and loses color depth, and later works fine through some meshes becomes invisible, menu also has this strange scaling issue where it also flickers and the screen goes black and you see only minimized, i tested it later with cnc-ddraw and i found that the game works but the moment you quit a mission or completes it, the game crashes.
it would be nice if dege could investigate this issue with ddraw.dll compatibility because its happening without reshade's own dxgi.dll.
Also on a note, i decided to test the battlepack edition of GBL and it didn't work accusing missing files, later i got a virtual machine and patched it to 1.05 and it didnt work either because even with the cd or image on the tray it claims that the cd isn't there.
Reply 296 of 571, by myne
It's great that you're doing this.
Are you able to take some notes on exactly what and how you're doing it?
If you're finding tweaks to dxwnd settings or dgvoodoo, it will be easy to incorporate for others.
And exactly what versions (there are about 40)?
You note gbl, but not which.
The simple way would be to copy the installers version string eg mw2-titanium-mw2titanium
Also, are you using the installer? Is it working for you?
I built:
Reply 297 of 571, by BEEN_Nath_58
Deffnator wrote on 2024-09-27, 01:27:
So i decided to install reshade now to see how it is with the games Both MercsD3D and MW2 3dfx works greatly, but Ghost Bear Leg […]
I think the screen flickering isn't related to dgVoodoo2. Can you check this: play a mission, exit it and then reenter, and see if the flickering happens?
Reply 298 of 571, by Deffnator
myne wrote on 2024-09-27, 02:25:
It's great that you're doing this. Are you able to take some notes on exactly what and how you're doing it? If you're finding tw […]
Yes the installer is working perfectly for the other mech 2, only Battlepack seems to be the issue.
As for Mercs, Enhanced 3d edition uses DDRAW primarily as its render since there is no glide support in this version.
Also something Dege could check it out but it seems that the voices ingame disappears as the voices and sound effects in menu, ill post the config now so it is easy to check it out.
The attachment mercswin 2024-09-27 10-17-45.png is no longer available
The attachment gblwin 2024-09-26 21-58-18.jpg is no longer available
Reply 299 of 571, by Deffnator
BEEN_Nath_58 wrote on 2024-09-27, 07:51:
The flickering is now fixed, i'll post both conf files at the dgvoodoo thread, the issue now is just the meshes becoming invisible and 3d mercs audio and not recognizing the ripped audio even with the most up to date version of winmm ogg.
