Reply 200 of 454, by DustyShinigami
- Oldbie
Shponglefan wrote on 2024-10-26, 13:47:That looks like hot glue. I have occasionally seen it in some systems. It's to keep the cables from becoming accidentally dislodged.
Try some isopropyl alcohol on them. It should break the glue's adhesion.
Bugger. On closer inspection, I believe you're right. But good to know that isopropyl should help break it; I have some. Thanks.
OS: Windows 98 SE
CPU: Pentium III Katmai 450MHz (SL35D)/Pentium III Coppermine 933MHz (SL448)
RAM: SK Hynix 128MB 100MHz/Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/Geforce 128MB 4 MX 440
Motherboard: MSI-6156/Abit BE6-II
