Reply 20 of 51, by maxtherabbit
- l33t
darry wrote on 2021-02-22, 17:09:Thank you, but unless I am misunderstanding, VGATV is meant to use a VGA card's output to drive a monitor that is 15KHz capable […]
maxtherabbit wrote on 2021-02-22, 16:53:darry wrote on 2021-02-22, 16:50:I think you misunderstand me . Sorry if I was unclear . I did not mean to imply using an EGA monitor on a VGA card. I was suggesting to use a TSR to force a VGA card into 60Hz when running EGA or CGA software while displaying on a VGA monitor .
VGATV does this
Thank you, but unless I am misunderstanding, VGATV is meant to use a VGA card's output to drive a monitor that is 15KHz capable . I don't see how it would work to drive a standard VGA/SVGA monitor, unless one also uses a scan doubler like an OSSC .
I was wondering about a way to get EGA and possibly CGA backward compatible modes on a VGA card to actually output directly at 60Hz to a VGA or SVGA monitor while maintaining the VGA card's native line-doubling (when required for 320x200 or 640x200) .
EDIT : As a bonus, if 50Hz could be maintained in Hercules mode, that would be great, though I do not think I even still own a VGA card with Hercules graphics compatibility .
oh right you did say VGA monitor, I just saw 60Hz
