Reply 20 of 24, by Alexis78
ripsaw8080 wrote on 2025-01-28, 23:29:
The issue has been resolved in DOSBox SVN, so the simple solution is to use a build of current source.
Relevant commit: https://sourceforge.net/p/dosbox/code-0/4266/
Thanks for the reply!
The thing is that I am using DBGL as front end, so It comes with the Dos Box 0.74-3 and I think I can´t change that.
So I will know how to proceed like they tell in the thread, using a Hex Editor, I am very near to achieve that but I need help in the last part of the case.
Reply 21 of 24, by Alexis78
The problem is that I am using DBGL and it has Dos Box v 0.74, can´t change that version of Dos Box.
Also, You are the great man that invented Dos Box? seriously? You are such a star then! oh!
Reply 22 of 24, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The "DOSBox Author" label can be misconstrued, so to clarify: Harekiet is the creator of DOSBox, Qbix is the lead developer, and I am one of multiple contributing developers.
If you insist on going the route of modifying the game to work around the animation speed issue, I suggest you look at one of my prior comments that mentions a modification that works well:
Using a hex editor or the like, search in the executable for the byte pattern 3A C4 75 04 and change 75 to EB.
Reply 23 of 24, by Calvero
Alexis78 wrote on 2025-01-28, 23:00:
Ok, but when I use the Search, copying "00ccc0 08 74 fb eb 0c 90[a0 c6 77 8a 26 c6 77 3a c4 74" it doesn´t appear, and I really don´t know how to do that, I never used a program like that. I must use Search or Replace? I copied correctly, I mean, is "00ccc0 08 74 fb eb 0c 90[b8 01 00 40 3d ff 30 75 fa 90" correct or I miss something? Where I use that in HxD?
At location 00ccc0 in the file you'll see the bytes 08 74 fb eb 0c 90 followed by the bytes between [ and ] that you need to replace.
Reply 24 of 24, by Alexis78
Calvero wrote on 2025-02-02, 15:28:
Thanks to explain to me, now I understand how to find something using an Hex Editor, but I can´t found the "00ccc0", I suppose Its the so called Offset, in the far left side of the screen that I show below, I use the search but nothing appears, maybe is my version of VGAB.EXE that I can´t found It.
