Toshiba 2805-s402 Ultimate retro gaming laptop
Reply 140 of 168, by pioner666
jnnelson79 wrote on 2024-02-14, 13:37:
After searching part numbers, I found this one on Amazon of all places. […]
vorob wrote on 2024-02-06, 16:40:
Anyone remember the specs of RTC battery in our laptop? Wanna buy a new one.
https://www.amazon.com/gp/product/B07XD25BCK/ … e?ie=UTF8&psc=1
I haven't had time to install it yet, but the part numbers matched what I found. after my research.
Thanks for the battery bios part number - already ordered for my laptop. also want to try repackaging the battery
Reply 141 of 168, by vorob
[quote=pioner666 post_id=1234839
[/quote]
Sir if you’ll do repacking make a guide please. With photos and so on.
Reply 142 of 168, by jnnelson79
Well, I finally found a 402!!! I’ve been looking for over a year. This one was on eBay, and it is in excellent condition, even including the stickers. There’s just a little bit of wear on the palm rest energy sticker and that’s about it!
It works perfectly, and the scaling is amazing! I already have a 401, so it’s cool to see them both working in their own ways!
Hope you can see the attached pic.
Reply 143 of 168, by vorob
Wow, this really looks like mint condition! Congratulations. Take care about hinges, if you notice they are getting tight, disassemble it immediately and clean / reoil them or else case will brake.
What was the title for this lot on eBay? I’m subscribed for Toshiba 2805 but didn’t see this.
Reply 144 of 168, by jnnelson79
vorob wrote on 2024-02-18, 05:32:
Thanks! It was listed as Vintage Toshiba Satellite 2805 Laptop
Very happy with it so far! I’m having trouble getting Duke3D to run with vxd drivers but I see that’s a common issue. It runs fine if I select Sound Canvas for Music and no sound card for sound effects.
Other strange issue is that if I use the WDM drivers, there is no sound in any DosBox games, most likely because there is no legacy sound system. It’s really weird. My 401 doesn’t have this issue, but the 401 is on Win98SE and the 402 is on the stock WinME.
Reply 145 of 168, by jnnelson79
Warlord wrote on 2021-10-21, 04:54:
:) ya, I have been experimenting a bit lately with the WDM driver for the 2805. And found that after I unistalled the driver. […]
😀 ya, I have been experimenting a bit lately with the WDM driver for the 2805. And found that after I unistalled the driver. I used uniextract on the cab file, and I can force the device manager to install it as "Yamaha DS-XG Leacy Sound System (WDM)" which is missing from the defualt install. No issues at all and it allows you to change some varables like the input outpot ranges of SB, FM, and GM in software for dosbox not that it matters. It also unlocks Sondius XG tab to enable or disable Synthesizer effects.
I might mod the drivers if I get around to it to do this by defualt. Sinces its way better.
Other experiment I did was use some tricks to install 2 Primary Fat32 Partiotions on the same HDD and 2 copys of 98se. Now I have 1 install with WDM drivers, and One with VXD drivers. So I get better compatibility with games. The VXD drivers, work with PowerYMF so you can use a 4mb wavetable, and work with YMFutilities. While the WDMs don't so there are tradeoffs. WDMS are a lot more forgiving, in dos games that can use dosbox that hate the VXD drivers like duke3d. VXDs work alot better with games that dont flake out like DOOM. Games that use MIDI extensivly if they work with VXDs than VXDs are better.
Anyways theres not another laptop like these. All of the other ones the comprimises are too great. You eiter have bad video, bad audio, or a combination.
contemporaneously with this one you get good video and workible audio. That wasn't availible in anything else together at the time, and never availible in anything else afterwords. Funny thing is no one ever cared about this laptop. I don't even think it sold well.
Hello! Can you explain how you isolated the legacy audio driver from the WDM package? I’m not quite following what you posted above.
My 402 works perfectly on every DOS game I’ve tried except Duke3D. As mentioned earlier in the thread, Duke3D doesn’t like the VXD drivers at all. However, if I go back to the WDM, I get no sound in any DOS game at all inside of Windows. I’m using the stock Windows ME installation for now, but I don’t think 98 would be any different.
Any advice on how to get Duke3D working? It works with just music enabled through Sound Canvas and sound effects disabled, but that’s no fun. 😀
Thanks in advance!
Reply 146 of 168, by vorob
Just play build games in pure dos, that's the way.
Reply 147 of 168, by jnnelson79
vorob wrote on 2024-02-18, 10:08:
That works for sure, but I don’t think you can get that awesome general midi / sound canvas sound working in pure dos, right?
Reply 148 of 168, by vorob
That’s correct. If you’ll find a way to have sound and gm in windows please share. I desperately need this 😀
Reply 149 of 168, by wierd_w
Yamaha softsynth xg (lite)?
It came bundled with eidos ff7 for pc, bitd. A little cpu hungry, but could fake out being a general midi device in dos games run under windows, as I recall.
Kinda a shit bandaid if you have hardware xg present... but meh.
As for getting general midi working... does the xg synth support an mpu401 'compatible' interface?
Could say, the parallel port opl2 driver be modified to redirect mpu401 to its io port?
Reply 150 of 168, by Guigui59210
Hello, being the new owner of a 2800-500 that I was able to obtain on ebay, I wanted to know if someone was able to upload bios 1.20 because it's no longer downloadable from the Toshiba site, my 2800- 500 has bios 1.6X but the fan is really noisy, I thought I read that an earlier version allows it to run more slowly
Reply 151 of 168, by Thermalwrong
Guigui59210 wrote on 2024-02-26, 20:50:
Looks like I have 1.20 here for the 2800-500, hopefully that works for you.
Reply 152 of 168, by vorob
It’s funny to note that 2805 uses thermal pads instead of thermal paste as heat conductive. Same thing I saw in other pentium 3 laptops. 🤔
Reply 153 of 168, by Guigui59210
Thermalwrong wrote on 2024-02-27, 02:09:
Hooo thank you very much I test that when I return to my house! 👍🏻
Reply 154 of 168, by Guigui59210
vorob wrote on 2024-02-27, 06:57:
I don't know if replacing it with a newer one will provide better refresh performance.
Reply 155 of 168, by Guigui59210
I tested and everything is fine, the fan is much more adjusted with bios version 1.20, perfect! THANKS
Reply 156 of 168, by jnnelson79
I’m definitely noticing the hinges getting tight now. The weird thing is that my 401 that I’ve had for a year now seems fine. Is there a disassembly guide anywhere, or does anyone here have video or photos of disassembly? I’ve repaired a Toshiba 400CDT and an IBM 701C Butterfly, but they had really comprehensive service manuals.
I’ve got the white lithium grease for the hinges, and it worked great on the 701C which had completely frozen hinges. I’m just nervous about taking this apart blindly since it’s so rare. I don’t want to break any plastic since a lot of these older laptops are held together with plastic clips. The 400CDT is much older but also had several brittle pieces break during disassembly.
Any advice you can give is appreciated!!
Reply 157 of 168, by Guigui59210
That can you help for disassembling
Reply 159 of 168, by vorob
I dismantled my samples without much guidance. Luckily, it wasn't too difficult, except for removing the hinges from the palm rest; had to maneuver a bit to eject them.
