First post, by agapecrusader
Hello I am trying to play 11th Hour using Dos Box .62 I emulated the directory c:\games\11H which is the default directory where 11th hour is saved and executed the batch file required to play the game as instructed in the game's instructions, however DosBox returned with the error
MSCDEX returned version 2.23
Error Could not find groovie dir (cd not inserted)
However i checked to make sure the cd was inserted. and i inserted it in both drives D: and E: before posting this thread
Any suggestions? btw i will look into some other threads concerning MSCDEX also to hopefully find an answer
Thanks
