New Windows 98SE Build
First post, by Matrolisk
I'm planning on building a Windows 98SE computer for playing old games from that era. Have a lot of old games collecting dust...it's time to fix that.
The computer is not going for 100% authenticity in all parts.
CPU-Intel PIII SL5B3 - No IHS - OWNED - Will need good cooler, quiet.
MB-ASUS TUSL2-C - OWNED
GPU-nvidia GeForce2 Ti
Sound-Creative Labs PCI Sound Blaster Live
Memory- 512MB 2 x 256MB PC133 SDRAM 168 pin
PSU-EVGA SuperNOVA 550 GM, 80 Plus Gold 550W, Fully Modular (Overkill Yes, but I wanted something new, modular and quiet) Will need 24-20pin adapter
Storage-Kingston A400 240GB (Not Sure on size yet, also trying to find a good sata to ide adapter like this (https://www.ebay.ca/itm/224957171336?hash=ite … %3ABFBMsO_Cn4Vh, It lists both 160gb and 500gb limits)
I'm also debating on a ethernet card and an sd port for transferring files.
Case-Something Simple like CORSAIR Carbide Series 175R RGB or smaller.....also consider building one from scatch...not sure how to do the back panel though
I'm planning to mod the case to make it look cool....still haven't decided on theme.
Any advice on this would be greatly appreciated.
Reply 1 of 16, by Joseph_Joestar
Matrolisk wrote on 2022-10-31, 01:11:
For Win98 stick with a 127 GB drive or smaller. The OS cannot properly recognize drives larger than that, and using something bigger will eventually result in data corruption. It's not enough to simply create a smaller partition, the actual drive size matters.
Phil has a video which explains this in more detail.
Reply 2 of 16, by Duffman
@Matrolisk
Windows 98 has a bug in it's ESD1_506.PDR driver where past the 137GB barrier it will wrap around to the start of your drive and start overwriting data.
rloew made a patch for this that will resolve this though -
https://rloewelectronics.com/distribute/PATCH137/pro5.3a/
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 3 of 16, by dormcat
Like Joseph_Joestar and Duffman said: 240GB is way too large for a Win98SE build; my very first WinXP build back in May 2003 had only an 80GB HDD (that HDD is still alive today). WinXP did not support 137GB / 128GiB natively until SP1. The manual of TUSL2-C did not specify the largest HDD it supported either.
Theoretically you could install a separate Ultra ATA/133 controller card that supports >137GB HDD, but it would only increase the chance of incompatibility. You really don't need a 240GB HDD for a Win98SE build unless you'd like to dump >200 CD-ROM ISO inside for virtual CD.
Reply 4 of 16, by mrzmaster
I've been using the 120GB version of the Kingston A400 in my retro builds with great results.
Additionally, for a PSU, I recommend going with something like the EVGA 500BQ or Corsair CX450M, since they have a 20+4 pin connector.
Reply 5 of 16, by Matrolisk
Joseph_Joestar wrote on 2022-10-31, 04:22:
It's been a long time since I used 98, didn't realize there was a hard drive size limit.
Will definitely consider something the the suggested Kingston A400.
mrzmaster wrote on 2022-10-31, 14:51:
Wanting to go for a clean build, would something like the Rosewill PHOTON-550, 550W work? It says it has the 20+4 pin connector.
Reply 6 of 16, by mrzmaster
Yes, that psu should work well, as you can just plug the 20 pin connector into the motherboard and leave the 4 pin aside.
Some newer psus just have a 24 pin connector and there’s often obstructions (like capacitors) right next to the 20 pin on older motherboards.
Reply 7 of 16, by dormcat
mrzmaster wrote on 2022-11-02, 00:30:
Some older motherboards with only 20-pin ATX also have capacitors blocking off-center (from 20+4-pin connector) or larger connector clips. MB designers had only very specific PSU connector in mind and forgot to leave some room for other models.
Reply 8 of 16, by Matrolisk
Any suggestions on a good cooler? I'm thinking of 3d printing an adapter to use a 120mm fan.
That way I can use lower rpms making it quieter while still getting good airflow.
Can I use any 168pin ram as long as the total capacity is supported?
I've seen some ram chips with a 32Mx64 on it, which I'm not familiar with.
Also any thoughts on my GPU and Sound Card?
I know that some people prefer the voodoo cards for glide but can't find any reasonably priced at the same level as the GeForce 2 (Voodoo 5)
Reply 9 of 16, by dormcat
Matrolisk wrote on 2022-11-03, 00:54:
IMHO the stock cooler/fan should be sufficient for a Coppermine P3; just replace the fan with a new one of the same size if it gets older and/or noisy.
It really depends. The manual said it can take up to 3x512MB, but if I were you I'd just insert 2x256MB. Note that double sided RAM are usually more compatible than single sided RAM of the same capacity (i.e. smaller capacity per chip = better compatibility).
GPU: GeForce4 Ti, GeForce FX (just be sure the cooling fan works and is quiet enough), or Radeon R300
Sound: SB Live! or Audigy for EAX, Diamond Monster MX series for A3D
Reply 10 of 16, by Matrolisk
dormcat wrote on 2022-11-03, 08:34:
I don't have the stock cooler for the cpu, so I need to buy something.
From what I've read the TUSL2-C only supports 512MB of ram so I'll look for 2 stick of 256 double sided ram.
The chipset only supports 4x AGP so I'll have to go for a GeForce 4 Ti
I can't find an MX300 card for A3D 2.0, or any card that supports it. So for now I'll stick with one of the SB cards.
Reply 11 of 16, by Joseph_Joestar
Matrolisk wrote on 2022-11-04, 00:58:
That's pretty much the perfect amount, since Windows 98 (and ME) can encounter problems when going over 512 MB RAM. There are third-party patches which can remedy this, but games from the Win9x era don't really benefit from having more than 512 MB.
Excellent choice. A GeForce4 Ti provides both good compatibility and superb performance for a Win9x system.
If you plan on using a surround sound system (for example 5.1 speakers) you're better off with an Audigy 1 or 2. But if you're playing using normal stereo speakers or headphones, then the SBLive is good enough. Note that later SBLive and Audigy drivers include A3D 1.0 support as well, so they will work fine for older games which only use that, like Dark Forces 2 for example.
Reply 12 of 16, by dormcat
Joseph_Joestar wrote on 2022-11-04, 06:37:
And less heat problem too. I always treat GeForce FX like Pentium 4 with NetBurst architecture: they provide marginal performance upgrades at the expense of far more power consumption than their respective predecessors (GeForce4 and Pentium 3).
Off topic question for JoJo: Have you ever used any AMD Steamroller CPU? 😆
Reply 13 of 16, by Joseph_Joestar
dormcat wrote on 2022-11-04, 06:51:
Yeah, the GeForce FX cards are nice if you want to crank up AA and AF in some later Win9x titles, but that extra power comes at a cost. They need slightly newer drivers (starting from the 4x.xx series) which a couple of older games don't like. There's also the text corruption issue which I recently became aware of, and of course the extra heat/noise. A GeForce 4 Ti is a lot more manageable while still offering plenty of performance.
ROAD STEAM ROLLER DA! 😁 Heh, no I haven't tried one yet, but I guess I'll have to at some point. I do carefully watch the Hamon Ripple on any PSU that I get though. 😉
Reply 14 of 16, by Matrolisk
So based on the advice provided this is the updated build.
CPU-Intel PIII SL5B3 - No IHS - OWNED - Will any socket 370 cooler work? (For motherboard compatibility)
GPU-Either the ASUS NVIDIA GeForce4 TI 4400 128MB V8440 or XFX Geforce 4 TI 4200 128MB DDR SDRAM AGP 4x GRAFIKKARTE
(Not sure if the first is 8x or 4x and it's about $75 more)
Sound-Creative Labs SB0090 Sound Blaster AUDIGY
PSU-Rosewill PHOTON-550, 550W
Storage-Kingston A400 120GB
Also would something like this work for transferring files?
https://www.ebay.ca/itm/193578823084?hash=ite … %3ABFBMlq7V1Yhh
Reply 15 of 16, by dormcat
Matrolisk wrote on 2022-11-05, 01:40:
You seem highly concerned about cooling; the TDP of your SL5B3 (Pentium III 1000EB) is only 29W so any average quality thermal paste + heatsink + fan can handle with ease.
IMHO "$75 more" is way too much to justify the slightly increased performance. I got my Radeon 9600 Pro (Gigabyte GV-R96P256D), GeForce FX 5600 XT (Asus V9560XT/TD/128M), and GeForce4 Ti 4200 8X (ELSA Gladiac 528) for US$32, $16 (both from auctions), and $5 (from e-waste), respectively.
Certainly, just remember the SD card would be considered as a fixed HDD and NOT hot-swappable.
Reply 16 of 16, by Joseph_Joestar
The AGP4x versions of GeForce4 Ti cards are more desirable. They can use slightly older drivers and also overclock better (if one wants to bother with that).
And yeah, the Ti4400 is not worth the extra $75 for only a slight increase in speed over the Ti4200.
