Syndicate Plus
First post, by jez
I'm seemingly the only person to have this problem, but my legit version of Syndicate Plus doesn't want to work with a recent CVS build (version number? The only thing it displays is 0.58). It crashes out after I select either 'Syndicate' or 'American Revolt' from the initial screen:
Error [35]: Unexpected Interrupt=0003 in DOS4GW.EXE at 0000:0000
code=0000 ss=01AF ds=0267 es=0267
ax=C190 bx=D494 cx=0000 dx=D4AE sp=6CDE bp=C1DA si=0004 di=D4A9
Now I know this is an unsupported version of DOSbox, but still, I thought it warranted reporting as nobody else seems to have had a problem running Syndicate+. I have no idea why it won't run.
On the plus side, DOSbox emulates Magic Carpet well, albeit verrrry slowly 😉; even the sound effects work!
== Jez ==
Reply 1 of 1, by icemann
Everyone (who has the syndicate plus version anyway) has the exact same problem jez. The only work around at present is to run main.exe (which skips the choice screen + intro) from your "syndplus/syndicat" directory. The only problem with that is that you can only play the standard campaign for Syndicate. Hopefully we`ll be able to play Americain Revolt in future cvs releases.
