First post, by Brusura2
Hello, Requiem Sneak Peek, the demo, doesn't work for me, simply after the double click nothing happens.
I have a GeForce 2 GTS Ti with Asus driver 44.03 and DirectX 8, OS WinXP
Someone can help me? Thanks
Reply 1 of 4, by Snover
Doesn't sound like it has anything at all to do with OpenGLide.
Yes, it’s my fault.
Reply 2 of 4, by Guest
Well I have tried other wrappers, some have the same effects other make requiem starts but crash when do a new game
Reply 3 of 4, by Stiletto
Just like Deus Ex, Requiem: Avenging Angel supports Glide.
Anyhow, Requiem *should* have problems on XP to begin with. See http://www.ntcompatible.com/cdetail9205.html
(this may not work with the demo, though)
So - problem is likely unrelated to OpenGlide.
do the Fandango!" - Queen
Stiletto
Reply 4 of 4, by CraigG
There is a superior DX8 patch out.
Taken from the readme
Requiem: Avenging Angel by 3DO - US retail v1.2 -> v1.3 Direct3D patch […]
Below you will find instructions on how to update Requiem: Avenging
Angel to ver.1.3.
This update addresses the following issues:
* Enable DirectX 8.0 game support for Direct3D compatible Video
Cards.
This program will update your Requiem game from version 1.2 to version
1.3. You must have the 1.2 patch installed for the 1.3 update to
work.
DirectX 8 games look far better than Glide ever did, providing you have a DX8 compliant gfx card.
Athlon 64 3000+ stock
MSI NForce 4 K8N Neo Platinum
2Gb RAM
nVidia Geforce 6800GT stock clocks
SBLive! Platinum + Audigy ZS2 Drivers
WinXP Pro SP2
