First post, by Thequad31
Hi all
I can't get Glidos working properly for TR1 under windows 10 (it used to work under win XP SP3)
I play form original CD, french version.
Glidos launches perfectly if I do not select VESA emulation and if I do not select Use FMV Pack options
The problem is that the game display in a (very) small window.
Issue#1: VESA emulation does not work. If I select this option, (FMV are played from CD) I get stuck after the first movie (CAFE) I can hear the sound of the menu but nothing is displayed.
Issue#2: If I select Use FMV Pack options I get stuck after the Core Movie ... Escape movie doesn't display. the game stops.
For information I have also installed DosBox+Nglide+VoodooRush patch ... With this configuration the game is running perfectly ...
As I really the beautiful Hi-Rs textures from Glidos I really would pleased if someone could help me with thee issues.
TheQuad
Reply 2 of 6, by Thequad31
Thank you for helping.
Tweaking the DosBox used by Glidos is maybe the solution
I will give a try
As I nGlide is working fine for me. But I really like the HiRes textures that come with Glidos.
Reply 3 of 6, by Thequad31
That's it, I found the solution.
No need to tweak anything ... just use the Tomb Raider 1 Voodoo Rush patch instead of the original tomb.exe ... just like with Nglide actually..
This fix also the issue with FMV
Reply 4 of 6, by PhilsComputerLab
Nice, good to know!
YouTube, Facebook, Website
Reply 5 of 6, by Splinter
Hi Phil
I know this is an old thread, but it's worth pointing out that the good people at Glidos are giving away free unlock codes till the end of Feb.
I just downloaded Glidos on Win 10 x64 but it won't install, givng an MFC application error. Any thoughts?
http://www.compufixshop.com
Main rig Ryzen 2600X Strix RX580 32GB RAM
Secondary rig FX8350 GTX960 16GB RAM
Reply 6 of 6, by Splinter
****Please ignore. I re-downloaded the install file and it worked fine.
